2012-03-05 08:09 PM - last edited on 2023-05-23 02:43 PM by Rubia Torres
2012-03-06 02:38 PM
2012-03-27 10:15 PM
David wrote:I have a more interesting question about intersecting a single plane roof with a multi-plane poly roof in AC15. I have been using AC for 17 years making roofs sing and command clicking to make roofs intersect with out problem. Now I want to simply make the ridge of a new shed roof intersect with just one plane of the multi-plane roof that is on the existing conditions.... but command clicking does not do anything... How can I make this work.
viktorik:
The video was made with with an ArchiCAD version earlier than 15, the Barrel Vault Geometry Method was removed from the Roof Tool in ArchiCAD 15 (it is replaced by the Shell Tool) so this video will not help. In the ArchiCAD 15 Help files see: Virtual Building > Construction Elements > Shells > Extruded Shells > Simple Extruded Vault: Parallel to the Floor Plan.
2012-03-28 03:00 AM
2012-03-28 02:05 PM
