roof help
Hi all i need help making roof. I want to maki it ellipse shape it is 1.6m from level 5 and go ih heigh it hase shale of ellipse and cut in half.
is it posible to make this roof like in autocad to select start point end point and type heigh and then type how long is ?
like on this pic. new roof shape is thin blue line on top.
my mail iz [email protected] if you need and info.
Thanks
4 Replies 4
Dwight
To create a roof like this you do not make a roof.
Haha.
Archicad is like that.
You make a sectional fill shape called a complex profile and then you extrude it as a wall.
See this:
Uncle Eric's Complex Profile Tricks
It is better because you can put all kinds of trim details in the section to make it look more like a roof. And edit the form more quickly.
Dwight Atkinson
with roof tool i made this but can't cut some parts of roof
Dwight
Too bad.
Throw all of the roof away and make it with the complex profile instead.
Give it a chance.
You will shout joyous cuss words of amazement!
Dwight Atkinson
Dwight
The extrusion follows the wall, straight or curved.
To trim, use a Solid Element Operation
Dwight Atkinson
