roof trim problem
Hello.
I have problem with trim roof. I have archicad file that i must edit. When i Trim to roof it trims to top of roof instead of bottom.
Is this some simple mistake or where i must look to solve this?
On new plain project it works.
Thanks guys,
Jan
4 REPLIES 4
sinceV6
Hi.
You should check Building Material priorities.
Best regards.
sinceV6 wrote:
Hi.
Best regards.
Yes, you are right
Thanks SinceV6
xterminal wrote:
sinceV6 wrote:
Hi.
Best regards.
Yes, you are right
Thanks SinceV6
Just to clarify for those others playing along at home - the building materials of the roof need to have a greater strength than the wall so the roof cuts the wall rather than the wall cutting the roof.
David Maudlin
xterminal:
If you use Solid Element Operation rather than Trim, the Building Material strength is not an issue.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
