‎2010-10-29
06:27 PM
‎2023-05-23
04:47 PM
Rubia Torres
‎2010-10-29 07:22 PM
‎2010-10-29 08:13 PM
‎2010-10-29 09:14 PM
jfanjoy wrote:After creating your SLAB in the shape of your connector... View it BY ITSELF in the 3d Window... For your particular part, you would want to view an ELEVATION from 90... so what you see in the 3d window is the TOP of your resulting "t" connector.
OK, that sounds like a good idea. It's about time I learned how to make library parts, anyway.Is it possible to make a library part without starting a blank project just to make the part? I tried using the directions in the AC14 Reference Guide. I selected just the parts in question within my existing project file (the T-plate and some bolt heads I added) , but it saves my entire building model as the library part.
Oh, and thank you for your regular posts. Your replies have been very helpful, both to my questions specifically as well as all the other threads I've been learning from.
‎2010-10-30 12:00 AM
‎2010-10-30 12:49 AM
jfanjoy wrote:ArchiCAD will always try to make the lower left hand corner 0,0,0....
Is there a way to define where you want the origin of an object, or the x/ y/ z axis to be located so you have better control of where it inserts into the main model?
‎2010-10-30 12:51 AM
