ā2007-03-02
11:52 AM
ā2023-05-23
05:10 PM
Rubia Torres
ā2007-03-02 12:23 PM
WENDY_NEVERLAND wrote:Use the 3D window elevational view to look at the light object (the way that you would wish to see it in plan). Now save the light object as a new GDL object using the File>Libraries and objects>Save 3D model as.
hello there.
do you know if and how can i rotate an object in 3d ?
for example i have a neon lamp that sends the light down and i want to send it on the left or on the right
ā2007-03-02 12:50 PM
WENDY_NEVERLAND wrote:If you don't have any rotateaxis variables in parameterlist, then you will have to do as Philip said. (Or, there are way more ways too go, but that needs more knowledge about GDL)
hello there.
ā2007-03-05 09:04 AM
ā2007-03-05 10:39 AM
ā2007-03-06 08:28 AM
ā2007-03-06 06:25 PM
ā2007-03-07 09:46 AM
ā2007-03-07 10:09 AM
Granville wrote:You should not save in elevation view, you should open 3d view, and move camera so you are looking at your object from above and then choose to save as GDL object.
Got much the same problem but the save in elevation trick doesn't seem to be working. Any suggestions for this please?
ā2007-03-07 10:36 AM
