ā2007-03-02
11:52 AM
ā2023-05-23
05:10 PM
Rubia Torres
ā2007-03-07 10:50 AM
ā2007-03-07 09:28 PM
Philip wrote:I followed your instructions and it worked perfectly!Granville wrote:
Got much the same problem but the save in elevation trick doesn't seem to be working. Any suggestions for this please?
Here is a quick illustration. I have used a simple curved wall but this works with any complex structure that you can build in plan from walls, slabs, roofs etc etc. - even other gdl objects.
ā2007-03-07 11:10 PM
ā2007-03-08 10:34 AM
Granville wrote:
Yeah, I Second that...
It works, and thanks for the illustration. Really helps.
Question, however, for Graphisoft...
...How difficult would it be to have a ROLL icon on the Pet Pallet, to do the same as Rotate, but on a Horizontal Axis. Between the two, any axial displacement could be obtained.
Surely they could provide a simple Pan and Tilt command.
ā2007-03-08 11:00 AM
Philip wrote:Yes that is the rub. Everyone says they want freeform tools, and then when they are provided there are complaints that they aren't parametric, or can't be scheduled, etc.
I would guess the answer is that it would be possible but one has to be careful of detracting from the general principles of ArchiCAD.
ā2007-03-08 12:56 PM
ā2007-03-08 03:54 PM
ā2007-03-08 07:56 PM
Granville wrote:
It is when a lateral solution solves the problem but rather in spite of the system, instead of by its very design, that it calls into question the requirement for such facility to be incorporated.
