rotation of an object in section
I am designing a very tight residential auto ramp. To prove our recomendated solution, I would like to show a car can navigate it in section. However, I can not find a way to rotate an object ins section.... is there a way.
10 REPLIES 10
I have downloaded a Ferarri spider free from www.Archibase.net (I think) (try a search for a01972) that has x and y rotation coded into it. Also a Porsche. Maybe some others. If these are any good to you have a look at Archibase.net, or let me know by PM and I will send you these ones.
BTW, they also come with a moveable option for animations.
Alternatively, if it is only needed for the section, select, copy, paste, rotate lines.
Link
Yes, or one of the 2D car library parts available in the ArchiCAD library!
Link.
Djordje
Yes.
Choose a car that has the rotation angle (all the cars from the Silver Bullet - aka 20th Anniversary libraries do), measure the angle of the ramp and input it into the rotation field.
Alternatively, just put the 2D car object from the standard library in the section and rotate it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje
OUCH!!!!
No lines, please ... the standard lib has 2D objects of the cars.
Djordje
HP Omen
Of course, sorry. Long day....
THANKS LOADS GENTLEMEN! for my uses the copy and paste worked real well.... put the 3D car in the plan...open section...and copy the 2D...relocate and paste...then rotate as needed....easy as can be.
objects that can be moved in section etc. easily still appear to await AC 10 or later...?
Paul
Djordje
Hm?
Why could you not move them before? Rotating is another thing, of course - depends on the type of the object.
Yes, 10 brings more editing to the S/E windows, provided you know how to select the right thing. Personally, I prefer 3D window - there I can see what I am doing.
Djordje
HP Omen
Yes, but sections have the advantage of being able to detect ALL the edges.
The easiest way of doing this is as follows.
Place any car from the existing library parts on your plan.
Put the marquee around it.
Get a parallel elevation view of from the side and save as a gdl object- call it say 'car1'.
Go back to the plan and place your 'car1' there.
It will look like your car in elevation but it has 3d properties.
Rotate the car in 'elevation' to the angle you prefer.
Put a marquee around the rotated 'car1'.
Get a parallel view from the 'top' of your apparently rotated elevational car.
The view looks like you are seeing it in plan.
Save this as a gdl object and call it 'car2'.
Go back to your library and place car 2 on plan. Get a 3-d view of it, and voila! You have your rotated car.
