2006-05-18 09:42 PM
2006-05-18 09:56 PM
2006-05-19 06:23 PM
2006-05-19 06:59 PM
Haneef wrote:Archicad and Plotmaker do not deal with AutoCAD CTB or STB pen table files in any way. It would be really nice if it did, but I suspect those file formats are not available through OpenDWG or any other source.
The quick and easy way of publishing to AutoCad and other formats has really been one of the best features of Archicad and plotmaker.
Anyone know if Plotmaker can create Autcad plotstyle files when publishing to .dwg format? I've been searching for it and quite sure it doesn't exists.
Would be great if it could, especially when you need to export files with lines set as hairlines. I often find that drawings I convert are printed really badly by other consultants, where they set all line thicknesses as one type, etc. Being able to produce a plotstyle file will improve this.
2006-05-21 06:35 PM
2006-05-22 03:16 AM
2006-05-22 08:17 PM
2006-05-23 01:56 AM
2006-05-23 08:05 AM
Eric wrote:Very true. I've seen cases where custom fills convert very differently from plotmaker. On one consultants cad program, circular columns opened up as diamond shaped columns. A direct export from ArchiCad 9 solved the problem.
One of the benefits of PM being integrated into AC 10 is that when you publish a layout you get "real" dwg data. In PlotMaker all drawings were really PMK equivalents. That is to say that everything was dumbed down to simple elements like lines, arcs, fills, text. For example, exporting a dwg from plotmaker would effectively explode dimension strings, etc.
2006-05-23 05:29 PM
