second floor
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-08-24
09:04 AM
2023-05-25
05:32 PM
Rubia Torres
2017-08-24
09:04 AM
thank you in Advance .
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-08-24 09:40 AM
2017-08-24
09:40 AM
Walls, columns, objects, etc., you can just copy from one storey and paste on another, but you can edit them separately - if you change the ground floor nothing will happen on the second.
If you want them to remain identical then you can look at creating a hotlink module.
You will need to replace the ground floor elements with the module (can be done as you save it as a module - there is an option to do this).
Then place the module on the other storeys as required.
Now when you edit the original module (in a separate Archicad) you can then update the models to reflect the changes.
Stairs are a little special because really you only want them on the lower storey.
There really is nothing on the upper storey (except a hole in the slab).
You can then tell the stair to 'Show on home and one storey up' in the settings.
Of course if you have a 3rd storey then you will need to copy and paste the stair to the second storey as well (or include it in the module).
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-08-24 09:44 AM
2017-08-24
09:44 AM
Thanks Barry , it helps a LOT !!
