selecting w/the shift key held down on a PC
peter spellman
Selecting w/the shift key held down on a PC is acting weird. Can't pick edges, it seems as if the points are off in space somewhere. i have tried adjusting the mouse constraints, but this does not seem to do it. It also seems that when I use the wheel to move in and out it affects the selection also ( sometimes I can pick a corner point on a fill for example, but sometimes I can not)
Any suggestions?
Thanks in advance for your help.
Peter
1 REPLY 1
Djordje
Your grid snap is on. Turn it off.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
