heathldesign
selections deselect when zooming and panning
has anyone noticed that when you select objects, then pan or zoom the selected objects deselect? also if i select a window say, then open the settings dialogue goof around in there then click ok, the window will no longer be selected. this is obviously a bug. pain in the patoot. has anyone else noticed this or is it just my issue?
Heath
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
4 Replies 4
Lingwisyer
Guru
I have had no issues with this. A Mac thing? Though High Sierra has been out for ages... It would be pretty bad if they have broken something pre-Metal before they have gotten it completely working on Metal... Does it happen on other computers? In other files?
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
I have never seen such a problem.
  • If you are using a touchpad or a magic mouse, maybe it accidentally registers a click, and so it deselects?
  • Can you try with a different mouse?
  • Does it happen consistently, or every once in a while?
  • Anyhow, if it happens consistently, can you share a video about it?
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
heathldesign
Typical. for some reason, i can no longer make it happen. I was an issue that spontaneously happened with windows and doors, and now it doesn't. i have been using a magic mouse for years without issue and had not or have not changed any settings or habits. who nows. if it happens again i'll upload a video.
Thanks
Heath
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello Everyone,
I just stumbled upon the same issue on another channel, and found out what causes this!
It looks like there is a bug here, that causes the selections to disappear at zoom and pan, when the Partial Structural Display is set to "Core of Load-Bearing Elements only". If you set it to anything else, it should work just fine.
Once we fix this issue you will find it in the release note as fix #261535. Until then if you experience this, change the Partial Structural Display setting while you manipulate the openings.
Regards,
GRAPHISOFT
