shell ending perpendicular to ground
Hello!
Is it possible to get a shell's ending perpendicular to the floor?
In this case I need it because I need the two shells connecting properly.
If it is not possible, do you have any other idea how I can connect them properly?
Thank you!
4 REPLIES 4
Did you try to pull and do a SEO between them ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Hello Christophe,
Thank you for your answer!
I tried SEO, and it works fine, but I was wondering if there was some other solution.
Something like this option for the roof...
DGSketcher
Legend
You may find these links help...
Define Shell Contour
https://helpcenter.graphisoft.com/user-guide/88629/
Edit Shell Contour
https://helpcenter.graphisoft.com/user-guide/88630/
Managing Element Connections
https://helpcenter.graphisoft.com/user-guide/88611/
