shift + r and any attempt to type in distances stopped worki
Gus
Help, I cannot type in any distances for anything any more. Whenever I used to move something I would press shift + r then type in the distance I wanted it to travel and it would move that exact distance. I could also type in lengths I wanted a line to be etc. This function has completely stopped for some reason. I restarted the program. I tried to start a new project and the same thing happened in the new project. Any ideas about what is going on would be much appreciated. Thanks.
-Gus
Archicad 14 64 bit Dell laptop
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
Sounds like your tracker has been turned off.
Gus
Thank you. That was it. So simple. Much appreciated.
Madison WI
