Dave Brach
sinks not showing up in pdf
I am using the object "Basin Cabinet 14" but the sink is not showing up in the pdf plans for some reason. Anybody know how to fix this?
Dave Brach/architect AC28 Macbook M4 Pro OS Sequoia
3 Replies 3
You will probably find the object is mirrored.
There is a bug that will not print elipses in objects in PDFs if the object is mirrored.
It has been fixed in version 15.
You can also try to use a different pdf printer. I've had different results with those. I usually use DoPDF (which is free) and Foxit.
I hope this helps.
Dave Brach
Thanks, Barry; yes,it was mirrored.
