jagotv
smooth mesh?
I am new to Archicad. I have a mesh that has been generated from theodolite data and is quite bumpy (even when edges are set to smooth not ridged ) due to erroneous points from the raw data.
Anyone know a way to  smooth out the mesh? e.g. reduce number of polygons that make up its surface/ reduce number of nodes/points. or is there a specific tool for this like there is on other cad programs.
all the best,
Jago
4 Replies 4
Steve Jepson
it might help to see some pictures ?  Also, you may want to save the final object as a morph and smooth it that way  ?  you can send me the file if you like and I will see what I can do with it.  or upload it in a .zip file. download link ?    Here is a link to a KLM Theodolite file to KMZ file converter that might be of some use. ?   Archicad can open a .kmz (Google Earth File) - theoretically 🙂      KML to KMZ Converter Online - MyGeodata Cloud
jagotv
Hi Steve,
Thanks for commenting! I'll attach a link to a .zip of the Archicad file and you have a bash at it. https://drive.google.com/file/d/1NH4cR8T69joGxkAI8y2RQcX7UdJCusqy/view?usp=sharing
Oh and thanks for the kml tokmz converter!
all the best,
jago
Steve Jepson
sorry it took so long to get back to you about this. I was traveling and didn't take my computer with me.   It looks fine to me.  2021-09-27_15-48-23.png
If there are some anomalies you can edit the nodes graphically in 3D to a more appropriate location or height.    https://www.youtube.com/watch?v=pbQ-gZc0PMc   ??
jagotv
thank you Steve!
