snap to a point within a fill?
I've got a fill set as a 2'x2' grid (ceiling tiles). I want to snap to a point in that fill (at the intersection of tiles) to properly insert lights, etc. I can't seem to do this, though I'm sure there's a way. Any insights?
Dwight
make a special grid system alternative that matches the interval and snap to the grid intersections. [ ie: the tilted grid option need not be tilted]
Array/Matrix hotspots throughout your fill.
EDIT: I mean the background grid.....
Dwight Atkinson
David Maudlin
To follow up on Dwight's advise: set your Snap Grid to 2' x 2' Spacing (this will leave the visible Main Grid as is), move the User Origin to the Fill Origin (you may need to disable snapping to move the User Origin to the correct point).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Dennis Lee
The easiest way in my opinion, is to turn on the Fill Origin in the model view options. Then, you can move your lights there and move it 2' or 4' with the constraints.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
