special menu option in 9
I have gone into the reg edit file and changed the special menu option from "0" to "1", but when i reload archicad the menu is not there, it is also not in the customize menu area.
any help.
3 Replies 3
any help.
Do a Search of the forum. We talked about this at length already, and I gave screenshots. You need to go into your Work Environment and add the menu after enabling it.
Karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Aaron Bourgoin
Check out Karl's how to thread - here
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.1.0 USA
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
Thank you, that works great.
I had done a search, but did not find that thread.
