2008-07-09
02:48 PM
2023-05-26
02:48 PM
Rubia Torres
2008-07-09 08:33 PM
2008-07-09 11:18 PM
David wrote:Good as your tutorial was at the time, David, it is very much out-of-date.
Here is a link to a tutorial I wrote:
HERE
2008-07-09 11:53 PM
2008-07-10 12:42 AM
2008-07-18 07:53 PM
2008-07-18 10:10 PM
2008-07-18 11:38 PM
2008-11-18 11:58 PM
Karl wrote:So, I have a slab with holes cut in to create the frame/muntins, and the ID is "wallhole", and another slab that is glass...
Absolutely NO GDL script editing is required. The wall-cutting slab simply needs to be given the ID of "wallhole".
Starterr, The method given is the easiest/best way to create your window. In your case, create a fill in a section/elevation to define the shape/size. Copy the fill to plan and magic wand it into the various slabs required (glass and wallhole) and magic wand the frame onto it. Etc. Then save as indicated in David's tutorial.
