ā2012-02-11 09:39 PM
ā2012-02-11 10:55 PM
ā2012-02-12 12:04 PM
ā2012-02-12 05:59 PM
zoltar wrote:You want to be working with saved Views -which become your drawings...
how exactly do you mean? I understand the idea of the different cut planes for a given plan but do you mean a different height cut plane for the plan or a cut plane in the 3d document? Could I have copies of the same floor?
ā2012-02-12 10:03 PM
ā2012-02-13 01:19 AM
zoltar wrote:There is no 'copy'. You set up all of the settings to see things as you want - with properly named layer combo, model view options, etc - and then create/save a new view. Look at the documentation for how to create a View.
that is exactly what I want, however I didnt find a Copy option for the individual fllor plans. How do I do that?
ā2012-02-13 03:34 AM
zoltar wrote:
Here's my problem.
I have a large exhibition space 6 meters high. And I want to insert a new level at 3m over part of the exhibition space for offices etc. How do I go about getting to show the plan for the split level? I need to show the two separate plans, one at level 0 and one at level +3 but without creating two different stories. Or is that not possible?
Cheers.
