2008-01-21
01:34 PM
2023-05-25
05:11 PM
Rubia Torres
2008-01-21 01:44 PM
evivas wrote:There are 2 ways...
does anybody knows how can a mesh be splitted into different parts?
2008-01-21 02:00 PM
2008-01-21 05:01 PM
evivas wrote:No. Only straight cut lines are available.
using the split tool I can create a line. the problem is that I want to split the mesh using a polyline.
Can I use, in a way, the split tool by creating a polyline??
The second way does not keep the shape of cut mesh.
2008-01-21 11:30 PM
evivas wrote:You could try closing the polyline, then magic wanding a subtraction out of it. If you wanted to keep the separate parts, you'd have to copy the mesh first and repeat the process for each side.
