square spiral stair
How can I create a square spiral stair?
5 REPLIES 5
Dwight
make treads from slabs, elevated and rotated about the centre.
Trim the slabs back to the appropriate rectangle afterward.
i do not thins "Create stair from selection' works with this arrangement, but have a look at that, too.
Dwight Atkinson
Try this object made by Olivier Dentan:
It's for AC8 - AC12.
David Maudlin
itzelf:
Also, select the Stair Tool, change upper left pop up to "Find library parts" and search for "spiral".
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
thank you all. How can I import the object made by Olivier Dentan, Im having trouble using it.
You must load it:
