stairs trimmed to walls
if you have a wall that is 45 degrees to a stair case, can the stairs be trimmed to fit the wall evenly? if not, is there a way to draw the stairs around the turn without penetrating the wall?
by the way, how do you post a picture? to go along with a post.
13 REPLIES 13
Link
If you are creating your own custom stair, you sure can.
Simply click on the corner of the stair and the Corner Settings dialog appears. You can fillet or chamfer (45 degrees only AFAIK).
To add an attachment to a post simply hit the Browse button next to Filename, under the message body. The image has to meet the requirements at http://archicad-talk.graphisoft.com/attach_rules.php?f=2.
Link.
how did you get those pictures saved for the file to be attached?
Posting screen shots discussed here (Win and Mac platforms)
http://archicad-talk.graphisoft.com/viewtopic.php?p=40535&highlight=screen+shot#40535
among other places.
HTH
I only found how to do this in MAC not windows. How do you do it in windows?
Link
It says right there!
s2art said:
"...If on Win to capture a screen shot just hit Print Scrn button on keyboard at appropriate time, paste it to photoshop, paintshop, whatever, crop the image if necessary and save as jpg image. Then you can add attachment to forum (must be under 256k size)..."
If you want just the current dialog hit alt+prtsc.
Link.
Link.
I was not aware of that one, thanks Link.
Link
No worries mate. IMHO the mac offers better screen capturing.
In addition to what Marc said, you can capture a window pressing Apple+Shift+4 then press the spacebar and the cursor turns into a camera icon. You can then move the camera cursor over the window you want to capture (it becomes highlighted), click the mouse anywhere on the window and take the screenshot.
And if you hold down the ctrl key while capturing any screenshot on a mac, the image is sent to the clipboard and is not saved as a PDF.
Back to PC, SnagIt is a good screen capturing program that also allows embellishing without the need for additional graphics software. Costs about US$40 though:
http://www.techsmith.com/products/snagit/default.asp
Link.
thanx guys i over looked it.
I am trying to work full time and go to school full time so i am half asleep all the time.
Hey! that sounds like my life for the past year
fun, isn't it?
cheers,
dan
