storey height level changing !!
Hi all,
We have dragged story lines by right clicking etc. in the section but they return to the original location. We have also changed the values in the story settings and the lines have still not moved accordingly.
Thanks any tips are greatly appreciated
Myles.
5 Replies 5
Hi
Have you Re-build the model from the section?
cheers
hi...
my suggestion: change the story level in Story Setting then choose Re-Build in the Section
Thanks
myles wrote:
Hi all,
Myles.
If you go to the Story Settings Dialog and change Story Height, click OK.
Then if you immediately go back to the Story Settings Dialog, do the changed values stay put or have they already reverted to previous values?
Thanks for that - the values change and stay as we require however the the line do ney change in the section to reflect this accurately.
Any thoughts ?
I have no good ideas here.
I tried several things: setting the Section to Automatic rebuild, to Manual, to Drawing. Changing the display of Story Level Lines to None then back to Display. Locking the Section Marker in the Floor Plan Window or locking the Layer of the Section Marker.
It always works for me.
Maybe there is something with the file.
If you create a new Section from scratch, does it display the correct values?
