to turn off the sound
I would like to know how can I turn off the sound ArchiCAD does when using for example eyedroper and some other tools. I am a PC user. THNKS
5 Replies 5
on/off from "Sound and Audio Devices" (MsWindows Control Panel).
or you can go the folder and delete the files...or replace them with the simpsons....
C:\Program Files\Graphisoft\ArchiCAD 9\Sounds
thanks! it helps - i wanted to be able to use headphones for VOIP while working in ArchiCAD - so - this is the right solution not to get ArchiCAD sounds in the background while talking...
Result is same. Indifferent if you delete voice files or turn AC/PM voices off from "Sound and Audio Devices" (MsWindows Control Panel).
yeah - i see - thank you!
