trim slab to roof?
Not able to trim a floor slab to a roof without it trimming the slab vertically like a plumb cut? Does anyone know of a solution for this, and is this resolved in AC 11?
5 REPLIES 5
Stephen Dolbee
As far as I know it has always trimmed that way. Use SEO, instead.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
But if he delete other object used by SEO what will be happened with slab šŸ™‚
Despite my weirdness, I think I'd rather trim the roof to the slab. Thus, the slab could be 1 mm thick and the plumb therefore rater small.
While in the ideal user interface either might work, neither can be built, so my vote goes for my own proposal, in which The Parameter makes more sense (to me at least).
I like your design concept already! Perhaps Frank Lloyd would have loved it, too: the ethereal eavesline.
David Maudlin
Put the other object on a hidden layer.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Good idea. I'll do that šŸ™‚
