trim to roof
in AC 15 the way of Trim To Roof does not appear in its typical spot...and when found there does not appear to be a way of trimming above a roof...and below another roof for the same wall.
Recommendations are NEEDED ,
Thanks, Paul
Trim to Roof has been renamed Crop to Roof in 15... Choose Crop and you have all the familiar options...
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks for the Trim to directions....However, I guess that I am just a bit slow about all this because I do not find a dialogue box that has those directions listed.
Design/Connect/Trim...? but no subsequent trim either or.....?
Thanks, Paul
Trim is not what you want - it has a completely different function in 15 than earlier versions.
Crop in 15 is the same as the "old" Trim.
If you right-click a wall (e.g.), you'll see amongst the pop-up context menu commands the attached: Crop to Single-plane Roof
If you are using the new multiplane roof, then read about the new Trim commands in the help file and watch the youtube videos... Best done in 3D with the status bar displayed, to show you the steps to perform - you'll select the trimming body (roof) and then be asked to move your mouse over the part to be kept - which will be highlighted as feedback until you click and perform the operation - allows trimming the top or bottom.
