Gus
trimming to roof difficult problem
I have two somewhat overlapping roofs. When I trim the walls below to these roofs some trim to the correct place and some trim to the roof that I don't want them to trim to. Is there a way that I can select which roof I would like the wall to trim to and which roofs I don't want it to trim to?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W [email protected]
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
3 Replies 3
adzik
Try using Solid Element Operations. It gives you more control over what trims what and when you move the trimming object, then the cut object updates automatically. See ArchiCAD help for more details.
Running ArchiCAD 23 INT.
Gus
Thanks, I will give that a try. I really appreciate the help.
Michael
Madison WI
Hi Gus,
Select the wall and the roof you want to trim to, then right click (somewhere outside your model) and choose "trim to roof".
Hope that helps,
Adrian Tudoreanu
