HelenE
turning insulations around windows in section view
Hello everyone!
I had recently posted a question on how to turn insulation in plan view in windows and one of the members kindly helped me. I haven't found out how now this can appear in section view. Is it possible? I haven't figured it out... Thanks in advance!
2 Solutions
Marcus Scott
Unfortunately this is a limitation, the closure you see on floorplan is a GDL 2D Symbol. Whereas a section view takes the view from a 3D Projection because the closure doesn't exist in 3D it cannot be displayed in a section view.
Therefore you will need to manually add this detail using the 2D tools in Archicad.
Go to post
Tim Ball
You are not limited to 2D
you can add the closure separately as  a beam, maybe part of the lintel you need anyway using complex profiles
that way it appears in 3D and all sections and you can schedule it
if you carefully make the complex profile you can allocate structural and finishes too
Tim Ball
AC26, iMac
User since V5
Go to post
5 Replies 5
Marcus Scott
HelenE
Thank you so much for letting me know!!!
Tim Ball
Tim Ball
AC26, iMac
User since V5
I could add the options to my windows and doors over Thanksgiving
HelenE
That's a great idea! Thank you so much Tim! Sorry for the late reply!
