use curtain wall to make pyramid?
I am considering the method to create a glass pyramid by curtainwall tool. but due the some limitation in curtain wall. i can't do it....
do anyone know how? or an alternative
Thanks
8 REPLIES 8
i can use slant wall to create pyramid, i believe the curtain wall tool should be able to do so. but i just dunno how
This is done in 1 minute !
You can do this easily if u read manual !
I will post u tutorial, step by step but cant do right now, later today
Its very easy
I didnt rotate frames like in your pic but it can be done very easaly
Sorry, got to go now !!
Mats_Knutsson
5 mins coffe break play...
The help is good.
Now 150% back to work.
I guess you need to calculate the slant angle before so it all comes together nicely.
AC 25 SWE Full
sorry for overlooking the help file.
I now found some way to do so
design>curtain wall
but i still can't do fast and accurrate
how can you match the frames ?
design>curtain wall
Draw your model in some other 3d modeler (Moi3d, sketchp etc) then from there take dimesions and put it your curtain. . . i hope that u will do it
this time I draw it by calculating the angle.
Mats_Knutsson
Sweet!
Pythagoras theorem rocks!
AC 25 SWE Full
Actually,
it should be
Trigonometric ratios in right triangles
i.e. Sine, cosine and tangent
