vector fills in elevation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-11-05 05:25 PM
I want to show tile pattern hatching in a few of my interior elevations (see attached). I did this in exterior elevations by assigning a material with a vector hatch to the model. It doesn't work in my interior elevations, however. I checked everything in view settings, and they seem to match. What am I missing?
Also, is there a better way to do this, in general?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-05 05:56 PM
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-06 12:32 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-07 05:28 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-08 01:38 AM
In the new Material, re-assign the Vectorial Hatch to a fill that you like. Again if there is not a Fill pattern that you like find one that is close, create new fill from that fill and adjust the Angle and even the x & y spacing dimensions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-08 01:39 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-08 02:08 PM
jfanjoy wrote:Jay's suggestion is good particularly if you are using this fill multiple times. For single instances there is the Align 3D Texture command.
Is there an equivalent to this for 3D objects?
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-08 03:32 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-08 07:26 PM
1) The interior elevation is cutting a section through the ceiling thickness. In other elevations, I gave the elevation a finite vertical range to avoid this. In the case shown, however, I'm slicing through a sloped ceiling so the height is not a round number (and is also irrelevant for construction documentation purposes). Is there a setting that will make the elevation automatically stop at the bounds of the first encountered cut surface?
2) there is supposed to be a door seen in elevation in the wall just to the left of the seat (under the notes). For some reason it doesn't show up. (my layers are displaying correctly, it's not that). Is there a view or elevation setting i need to adjust? Doors show up ok in my other interior elevations.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-09 02:29 AM
2) Check the range (distance) of your section in the plan. It may not extend far enough to pick up the door.
