2004-04-28
07:00 PM
2023-05-23
05:28 PM
Rubia Torres
2004-04-29 03:41 AM
2004-04-29 06:30 AM
Mark wrote:No problem with raked plates - see attached screenshot. You have to check the parameter that says "Use wall top (or bottom) edge". There are actually a huge number of parameters to customize the framing accessory.
I was wondering if it was able to do raked (pitched) top or bottom plates. I don't think it can, if this is so it is almost worthless in my mind. If I am wrong about this let me know.
2004-04-29 09:37 AM
2005-02-11 04:21 PM
second: the position relative to the wall itself. i already have the walls in my file consisting of an 89mm cavity (for the studs) and plasterboard skins each side. the cavity has a fill type "cavity" and is checked as "Core" in composite wall settings: my question is how do i get the wall framing accessory to sit in the cavity/core and stay there after having moved it from where archiCAD puts it!?. my wall reference line is centred yet archiCAD insists on putting the framing on one side or the other. have i missed something? i can't find an offset anywhere . . .Did an answer for this ever appear? I'm fighting the same issue now, and Archicad always seems to place the studs at the face of the wall, not inside the proper skin.
2005-02-11 04:29 PM
2005-02-11 04:43 PM
2005-03-20 07:08 AM
