2010-08-07 09:35 PM
2010-08-07 10:55 PM
2010-08-08 11:13 AM
Karl wrote:
You either do not have the desired cut fill associated with the walls (e.g., the diagonal brick shown in your example) - or your Model View Options are set to hid the fill. Or your wall is below the cut plane. Or...
Attached is a simple wall with cut fill brick and note that for in the Model View Options, the cut fills are NOT over-ridden... Play with the Model view options to see the variety of drawings that you can get from a single model...
Hope that helps,
