i'm seeing an issue with the wall end tool in v13 where i'm using the returned end 13 object and wrapping 2 (brick and render) skins;
the wall end appears fine when the setting is to show entire structure, however if i switch to core only, the outer wrapped skin is not visible (as expected) however the inner wrapped skin offsets the width of the outer skin (see attached image).
the complex profile in question has different priority settings for each type of skin (10, 12 and 14 for render, brickwork and cavity respectively).
i've checked and this doesn't seem to happen with composite walls.
has anyone else experienced this?
