‎2009-01-26 06:57 PM
‎2009-01-26 06:59 PM
‎2009-01-26 07:10 PM
‎2009-01-27 12:24 AM
‎2009-01-27 10:05 AM
Rick wrote:so i'm going about it in a way that makes sense then. i just thought that there would be a better way to intersect walls that i was missing.
I split the wall to get the roof to cut it right...
...A part of a dormer is normally not desired in plan view, but needed for modeling (above the roof). I place those parts (in green) on another layer (exterior misc) that gets turned off for publishing.
Rick wrote:i use the same way as for the dormers. i normally have external walls wrap around slabs rather than slabs to exterior walls and just have a 'hidden in plan' wall to fill the gap. if i'm lucky the joins won't show in elevations.
One your bottom one... I have a composite that is just the sheathing and siding (1.25"). That is a situation where I would use that.. as well as wrapping all floor slabs.
‎2009-01-27 05:05 PM
‎2009-01-27 09:09 PM
