2004-02-26 08:05 PM
2004-02-26 08:09 PM
2004-02-26 08:21 PM
2004-02-26 09:04 PM
2004-02-27 03:31 AM
2004-02-27 03:40 AM
2004-02-27 12:55 PM
2004-02-27 01:03 PM
2004-03-06 04:08 AM
Matthew wrote:Better clean up in section, yes! Better wall intersections in plan, yes! (See
Until the composites are scale sensitive and clean up properly in section, they are of limited usefulness.
2004-03-06 05:24 AM
Geoff wrote:I agree with you, Geoff, regarding scale sensitive display of composites. I wouldn't want that for the reason you state. However, I would like the option of turning off the composite display in both plan and section, but retain the overall thickness of the wall--not just the core. I have no use for showing the core only, though I understand others do. There should be three options then: show composites, hide composites, show core only.Matthew wrote:Better clean up in section, yes! Better wall intersections in plan, yes! But scale sensitivity, no!
Assuming this would be adjustable, it would still mean having to set the tipping point across the entire file. What if I want skins to show on a typical floor plan but not on a framing plan, both at 1/4"? A Core Only display option is more flexible and more consistent with the established quickview architecture.
