Tom Krowka
.dwg to consultant
This is my first time sending dwg's to a consultant. What is the best way to export the .pln. It has three floors. Will all the floors be overlaid on top of each other? I'd rather send the engineer a separate drawing for each floor.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
Djordje
1. Get his DWG template and use it as a translation template. Set up the Translator.
2. Create a view set with hairlines and empty fills if the consultants does not want any fills (very common).
3. Set up the publishing set and save to DWGs. If saving from ArchiCAD it should go plan by plan (section, elevation, whatever)
4. If publishing from PlotMaker, make sure your consultant understands Paperspace
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
