wall opening is not coming as per arch window.
I have created this window with slabs and saved as window.But this wall opening is not coming as per arch window any idea why it is happening ?
9 REPLIES 9
Link
You need to give the slab that defines the hole an ID of wallhole and save it as a window again.
Link.
is it something like i have to do 3d scripting ??
Srinivas
Sachin,
View this topic
http://archicad-talk.graphisoft.com/viewtopic.php?t=14031&highlight=
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
No. Just make a slab that defines the hole you want. Make its ID "WALLHOLE" (without the quotes - caps optional) and include it when you save the library part.
Srinivas
Matthew,
Correct me If I am wrong as per the image what I feel is even after renaming the slab Id. You need to edit the script, see below link.
http://www.archicadwiki.com/TechNotes/Creating_custom_windows?highlight=%28TechNotes/%29%7C%28TechTi...
and a simple tip too.
ArchiCAD Services
iMac, Windows 10
Srinivas wrote:
Matthew,
Of course you can edit the script for more functions, but it is not necessary. Any slab with the ID "WALLHOLE" will be included in the saved script as such. Tom Waltz once posted a clever example of how to make a hole shaped like a cartoon character
here.
Just draw the shape you want the hole and include it in the part. No need for scripting.
Srinivas
Thanks Matthew and Tom,
That was really wonderful!!!
ArchiCAD Services
iMac, Windows 10
Hey Guys,first of all thanks for reply.I preferd giving ID as wallhole.But it is not working properly.Its link for my pln file can anyone look into this what is wrong with it.
http://rapidshare.com/files/16528072/arch_window.pln.html
Could you do the same thing for an arch door that has an opening of 6' by 15' and has a 4" by 8" band that goes around the arch?
