2023-04-07 11:34 AM - last edited on 2023-05-24 07:21 PM by Rubia Torres
Hello, I have a problem with wall ends when I want to use thicker line weight. Even when I connect them they don't clear in a way a want them to. I tried to change the position of the reference line but it did't help. The other problem is that when I connect walls from different material and I use "end wall with line" sometimes there is thin and sometimes there is thicker line as you can see on the two last pictures. I have been struggling with this issueThank you for your help.
Solved! Go to Solution.
2023-04-11 04:36 AM - edited 2023-04-11 04:37 AM
I have fixed the link.
This is an image of the setting you need to look at.
2023-04-07 01:44 PM
Could be that one of your materials is stronger than the core material.
Stefan
2023-04-08 10:46 AM - edited 2023-04-11 04:35 AM
In your wall composite settings, ensure the wall end lines are ticked.
Here is a post that will show you the dialogue.
https://community.graphisoft.com/t5/Document-Visualize-forum/Wall-Intersecting-Lines/m-p/358514
2023-04-08 12:06 PM
Thank you, I can try that - will you just please send the link once more? This one is not working.
