walls or profiled walls on roofs
HOW CAN I CREATE WALLS (FOR THE DRAINING) WITH LOW HEIGHT ON ROOFS?
BECAUSE I CAN NOT CREATE WALLS ON ROOFS
7 REPLIES 7
Do you mean parapets? (Short walls around the perimeter of a (usually) flat roof.) Just use walls.
If they need to slope to fit roofs below then use SEOs or Trim to Roof (old style).
but u can not draw walls on roofs!
You can draw walls at any height you like.
Get the height right and they will be on top of the roof.
You can also use the gravity tool to snap the base of the wall to any point on a roof surface automatically.
And as Matthew said - use Solid Element Operations (or the old Trim To Roof command) to trim walls to match the roof slope.
i mean sth like in the pic. the walls to be vertical and to follow the outer perimeter of the slopped roof
David Maudlin
To cut the top of the wall: create a copy of the roof, elevate it to where you want the top of the wall, use SEO to remove the top of the wall, put the higher roof on a hidden layer.
To cut the bottom of the wall: use SEO to remove the bottom of the wall.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Fran_ois Chatelain
No need of SEO or other fancy tricks, simply use the roof tool and create a very narrow roof at the desired height...
Cheers
Francois
François Chatelain
Worldwide Digital Imaging
Formerly posting as RanXerox
"A little bump will help blur your reflections"
You could also use an Inclined Beam to do that little piece.
