Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
walls
Hello, i have this problem:
http://www.nahraj-obrazek.cz/?di=313935835443
The partition should start inner side but it is stuck into another wall.
Thanks for advices.
ARCH 17
2 REPLIES 2
David Maudlin
MaRRa:
One option is to change the Building Material Intersection Priority of one of the walls so the horizontal wall is stronger than the vertical wall (the horizontal wall will cut the vertical wall).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Great ! Thx.
