what is this?
could someone tell me what this might be please (see below). whatever it is it's cutting through both the foundation and interior walls. i can't find any object there or wall or anything. there doesn't seem to be anything to select. i've turned on all layers and i don't recall putting anything there. if i move the foundation wall back from the corner the cut disappears. i'll post the next pick in a reply.
this is what it looks like after pulling the corner connection apart.
never mind. it was a wall segment that was above the cutting plane. i looked at a section, but i had the section just a little too far north to catch the wall. i knew i would figure it out as soon as i went through the trouble of posting
