why don't my windows show
This is a new ADU, see picture...all the windows WERE showing, but now they are empty openings, but when I click on an opening, the window shows in the Window Selection box, but not on the plan...
The windows WERE showing so I was able to take the picture, but today when I opened the file, they will not show, does it have to do with the Renovation filter?
The Renovation Filter is set to Existing and Show All, but no success....
Have tried everything I can think of...
Ok, so First of all, what type of windows are you using? because in the view I can see windows or at least frame and glass.
Are your windows custom made or from the AC Library?
Did you look into the model view options?
David Shorter
Check that the windows have the same renovation setting as the walls in whatever view they are missing. Each view environment has its own reno settings.
Check that, if the windows are set to projected, that the floor plan cut plane actually goes through the window, or change them to symbolic
Hope this helps
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
