GeorgieB82
Hole/Void through multiple objects
I have a garage I have drawn and I need to add the door opening (no actual door, just an opening) but the structure of the wall is actually 3 components; a beam and two walls one on top each other.
What is the best practice to create a hole through all the parts?
AC25 UK Solo
Windows 10 Pro, Intel Core i7-4790, 16GB RAM, NVIDIA Quadro K600
5 Replies 5
Bruce
Empty (or simple) openings for the walls.
For the beam (I imagine it's notched on the underside), you could:
1. Split into three and change the middle part to be what you need
2. Use solid element operations to notch, or
3. Add a hole to the beam (a pet palette option) of the size you need
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
I will go with a solid element operation there.
But also curious, could you try making a complex profile for that complete wall, instead of using two walls and a beam? Because if you are breaking the beam I assume is not a structural beam? If you can use a complex profile you could use a single empty door opening to do this operation.
GeorgieB82
I probably could have used a complex wall but as I'm only in my first week of using ArchiCAD that sounds too complex for me!
AC25 UK Solo
Ok. Thats great, I can tell you that you don't need to be afraid the complex profiles are not that complex at all, instead, it is a great tool and easy to use. Search for tutorials online and read the help about it, You'll love it.
Erika Epstein
Or you could use the door tool to put an empty door opening in each of the walls.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
