window are bigger than walls, help !!!
hello
I started to work with a model in archicad....all just fine...drawing walls...with the right values....BUT when I am about to add window (curve windows) the units are messed uo and it get too big !!!
how can I adjust the measurements to the walls?
I am quite new in archicad.
any help will be appreciated.
3 Replies 3
Place a smaller window and stretch it to the correct dimension.
Sounds like you need to attend a course in AC or at least read a book!
You ask a very similar question in January! - here
As suggested before, are you sure you are not modelling in millimetres, but the file is in metres perhaps?
Go to 'Options' then 'Project Preference' to check your Working Units.
It is not like AutoCAD, for example, where it makes no difference what unit you work in.
