archicad 12: Problem Inserting Doors
When I insert a door, it will not cut the wall opening or display the dor swing arch in 2-d. Any suggestions?
5 Replies 5
Link
Probably a Model View Option setting: Document> Set Model View> Model View Options... Check your Door Settings (and probably your Window Settings while you're there).
Link.
Link.
Thanks for the advice, but nothing i do seems to work. Where can i find the correct settings, or reset to the default settings?
Link
It may have something to do with your floor plan cut plane. Check the height of it, make sure it is around a meter or 3-4 feet. And check that the doors Floor Plan Display are set to Symbolic.
Link.
set doors to display symbolic, not projected (in the door settings)
xristina,
Once had something like this.
Turned out to be that I had story height
set to around one foot.
Bier
