Learn more
Robert H
window diagonal
Hi all,
I have two walls, which are cut with an angle as morphs. How can I create a window with an angle?
Rob
2 Replies 2
Lingwisyer
Guru
You converted your walls into Morphs? What is the reasoning for that? Can you work with the Slanted Reveal option?
Ling.
Robert H
Hi Ling,
thanks a lot! I did not know better how to create the angle, that's why I used morphs
