window opening lines
Hi all, i got to work in a big model made in 13, it has so many windows and i need to hide their opening lines. i knew how to do it in 12, but i cant find the way in 13.
Regards
Juan Moreno
8 REPLIES 8
I believe it is a Model View Option (MVO) setting.
I think in 13 it is globally all on or all off - you can't have a mixture of both.
This was changed in 14.
Thanx Barry, it would be fine all off, the problem is that in the MVO i still cant fine the right option.
Regards.
Juan
What library parts are you using?
The default Archicad 13 library or do you have another library that you use?
this model was made with the archicad 13 library, i uploaded the 12 library into the library manager and with that library i can hide the opening lines of my windows.
thanx
Juan
Yes in 12 it was controlled in the library part parameters.
In 13 it is controlled in the MVO.
I don't use 13 or the standard libray so I can't show you at the moment.
I will try to get a screen shot a little later (must go home now).
But in the MVO settings (Document menu > Set model view > Model view options) there should be a section for the version 13 library.
David Maudlin
Look for MVO > Options for GDL Objects > Show Opening Lines in 3D for Doors and Windows.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Here's the screen grab.
Thanx a lot guys!!!
Juan
