We value your input!
work-enviroment
Hi to all! My name's Luca and I'm new here!
First of all I'm apologising for my english, but I really need your help for a very annoing problem!
I'm taking an internship and I'm currently working on a project which was started by a girl who moved in an another studio, so I've started working on her AC12 files, here's the problem: I cannot see the true colors of the hatchs, I can see them only in grey, no matter what I'm changing.
I've tried with this:
option->work enviroment-> screen option -> Automatic Pen Color Visibility Adjustment for Model Views
but it doesn't work, any of you has an idea??
thanks a lot!!
8 REPLIES 8
You see Hatches in gray WHERE ?
1. On plans in Project Map ?
2. On Layouts ?
Did you check the Pen Sets?
Add your signature to the profile, so we can help you better!
Hi andro55
... definitely not in layouts, there I can see everything fine, so I suppose I should say on plans on project maps.. I'm sorry but I'm learning AC using it.. Anyway it's in the drawing area, where I draw the "floors" of my house
I checked the set pens, although without knowing what I had to look for, so any suggestion is really appreciated
Now I going to fill my profile.. thanks
Luca
David Maudlin
Luca:
One thing to check is the Trace & Reference palette > Active to see if it is set to Original Color. Some screen shots would help explain your problem.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
here we are, can you see that big gray area? should be orange 'cause I set orange on hatch properties
Find out!
if I disable the "reference plan" (icon is made by two trasparent square - one cyan and one yellow) I can see the colour.
But is it impossible to have both? I mean have colours and referece plan active at the same moment??
Thanks a lot
Luca
When you say you are working on AC12 files, are you working in AC12 or a later version on older files? I'm wondering if you're actually using AC15 if it is a Renovation Filter issue.
Add computer spec and AC version info to your signature, as "results may vary".
NCornia
Graphisoft Alumni
Graphisoft Alumni
Lucal,
Yes you can have both. Enable the Original Color scheme for both the Reference and your Active view. The color assignment is meant to be helpful in that it differentiates the two views, making it easier to work, but it is also customizable for everyone's taste.
Best regards!
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
@s2art: I'm working on AC12
@NCornia: Your suggestion was the right one
Thank to you all guys! now my life is colorful and is not a little thing
