2024 Technology Preview Program
working on projects on different computers
I want to work on a project created on a different computer... I know how to save the file and open it up but the library parts and textures i created do not come with the file. How do I export the library so I can open my project with all the correct components?
You should either copy the libraries to the other computer or load them over the network. It is possible to make an archive file which contains the library parts you have used so far, but you will not have any more to chose from. You need to give a little more detail about how you plan to work. Is this a permanent shift or will you be switching back and forth? Are you on or can you set up a network?
It would also be nice if there were an "automatic" way do carry over your latest favorites, work environment settings, keyboard shortcuts, customized schedules, etc. when you move from computer to computer. Right now it requires a constant stream of importing and exporting...maybe someone has a better way?
