Color by size
cuba
Graphic Override dynamically changes the colour of the zone according to its size.
>> Displays flats of the same order size and in the same colour
This is controlled by a parameter (opp2):
Graphic overrides:
Graphic overrides rule:
Comments
just for using parameters you already deserve a contract
zamotanya
I'm glad I'm not the only one who made these rules!😂
This is very cool and helps to immediately visually understand the scale with which you are working!
But I did not set up in such detail, a huge big job!👏👏👏
KonradL
Beginner
Great work! We're doing the same thing for initial design phase. What we're strugling with right now, it's automatic zone name change based on zone area.
Do U have maybe idea, how to do this?
@KonradL
This is a completion (challenge) forum and this particular challenge has closed.
Feel free to leave comments, but if you have questions, you will be better off posting them in the main forums.
